-   -   Ford 8 Inch which drum brakes? (41 ford) (http://www.hotrodders.com/forum/ford-8-inch-drum-brakes-41-ford-218682.html)
nba1341 04-27-2012 12:41 AM
Hello there I am working on fixing my Dad's 41 ford. The brakes were seized its been parked for years so after some beating I finally got the drum off. Pretty positive its an 8 inch and am trying to figure out which drum I need to get maybe someone can identify?
Drum is 12.5 inches total width. 10 1/2 inch pads
Pictures maybe can help?
http://dl.dropbox.com/u/40525714/For...3804a181_7.jpg
http://dl.dropbox.com/u/40525714/Ford/IMAG0199.jpg
http://dl.dropbox.com/u/40525714/Ford/IMAG0205.jpg
nba1341 04-27-2012 05:03 AM
http://dl.dropbox.com/u/40525714/Ford/IMAG0207.jpg
http://dl.dropbox.com/u/40525714/Ford/IMAG0209.jpg
delawarebill 04-27-2012 06:34 AM
rear
the pic of the back view looks like mine.. 8".. measure between the backing plates... mine is 54" and it came out of a 67 mustang.. ck the axle housing too... if they taper down it'll be a 64 to 66.. they changed to the same size tube in 67.. now there may be some cross over in the 67 yr.. but u'd be mustang, mavrick, falcon...
2old2fast 04-27-2012 08:11 AM
Look on the frt where the center section bolts to the housing , you may get lucky & the factory tag will still be there, then you can decode. 8" ford were used up until '79 , mustang II, granada, pinto , bobcat, monarch..
dave
