Ford 8 Inch which drum brakes? (41 ford) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2012, 12:41 AM
Hello there I am working on fixing my Dad's 41 ford. The brakes were seized its been parked for years so after some beating I finally got the drum off. Pretty positive its an 8 inch and am trying to figure out which drum I need to get maybe someone can identify?
Drum is 12.5 inches total width. 10 1/2 inch pads
Pictures maybe can help?
Old 04-27-2012, 05:03 AM
Old 04-27-2012, 06:34 AM
delawarebill's Avatar
rear
the pic of the back view looks like mine.. 8".. measure between the backing plates... mine is 54" and it came out of a 67 mustang.. ck the axle housing too... if they taper down it'll be a 64 to 66.. they changed to the same size tube in 67.. now there may be some cross over in the 67 yr.. but u'd be mustang, mavrick, falcon...
Old 04-27-2012, 08:11 AM
Look on the frt where the center section bolts to the housing , you may get lucky & the factory tag will still be there, then you can decode. 8" ford were used up until '79 , mustang II, granada, pinto , bobcat, monarch..
dave
9" ford drum brakes THERACER Suspension - Brakes - Steering 5 12-11-2011 01:43 PM
is there a ford rear drum 10 by 2 inch, for a 70mm spigot, rather than the 62mm nobler Suspension - Brakes - Steering 23 03-24-2011 12:19 PM
Separation anxiety - early Ford drum brakes Centerline Suspension - Brakes - Steering 11 03-21-2008 02:35 PM
9 inch ford disc brakes Tylor Sunaert Transmission - Rearend 4 08-23-2007 07:18 AM
69 ford drum to disc brakes bigdav Suspension - Brakes - Steering 1 02-04-2006 09:15 PM
