Ford 8 inch Posi Clutch Pack
Is it possible to make a non-posi carrier into a posi carrier? What is a posi clutch pack? Is this what it takes to do this?
This is for a ford 8 inch non-posi third member. If so I imagine that this can also be done for a 9 inch carrier as well. |
8" Trac-Lok
Ford calls their units Trac-Lok (short for Traction Lok), Posi is the inferior. Both 9" and 8" are Trac-Loks. The rears were available in 2 & 4 pinion "open" diffs (non Trac Lok) and Trac-loks.
Both have some parts than interchange. 8" Trac-loks are hard to find, there were alot more 9" T-Ls made. You can shim the side gears in an open rear to tighten it up and have it act more like a locker. Henry |
