ford 8 installation techniques?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 10:07 PM
when I removed my ford 8 inch there were copper crush washers on the lower 6 bolts that were a B*&#h to get off. when I put the rear back in it should I a). use a gasket b). use rtv gasket maker c). both a&b and also should I use these crush washers or something along that line or is just torqueing them enough? oh and do you recommend (dare I ask) synthetic or regular lube? I replaced the ring and pinion 3.00 to 3.80 and installed a right lock locker in it. thanks again.
Old 05-02-2005, 11:59 PM
aka Duke of URL
The copper washers are actually seals that prevent lubricant from seeping from around the mounting studs. FORD should still service these. I personally prefer the correct paper gasket. If you can see the cost of a synthetic, so much the better.
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
Windshield seal installation, 37 Ford Coupe Ted's37 Body - Exterior 3 08-14-2003 08:51 PM
2002 mustang 4.6 installation in a 1941 ford coupe 41fordcoupe Engine 7 08-14-2003 03:42 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
