Ford 9" 28/31 spline quickie - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 04:53 PM
Last journal entry: Future Plans
Need to know if i can take the 28 spline axle gear and put them in a 31 spline pot, i dont have any experience so much appreciated
Old 08-17-2005, 05:32 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi,
I worked in Ford parts from '79 to '92, and this is my recollection:
Yes, I'm quite sure that you can. I'm fairly sure that the OD of the hub on the side gears is the same on both 28 and 31 spline. The inside (spline) diameter is larger on the 31-spline and is inherently stronger.
28-spline were usually on passenger cars, and 31 were used on trucks and some muscle cars.
HTH,
Don
Old 08-17-2005, 07:04 PM
in need of some help again
Ok so here is the situation, i have the rear end im going to use which is 28 spline with a 350 open dif, now i have a 31 spline centersection with 4.11's posi and richmond ring/pinion .... now i was going to swap gears but they wont work physically
so now i need to know can i take teh posi and put it to the 350's pot or do i need to find some special gears to make them work
Old 08-17-2005, 09:37 PM
66GMC's Avatar
Shopping List
Check this site for a lot of good info http://www.fordmuscle.com/archives/2...ch/index.shtml
To answer your question:
Sorry, I must have missed the fact that one of these diffs was an "open" diff, so yup ... you're going to have to make a trip to the Ford store (or to a gear shop).
http://www.drivetrain.com/ford9.html#Ford%209
I think that all you'll need to convert that 31-spline carrier to a 28-spline is a pair of differential side gears.(#10,11 in the exploded view) The posi ones are a little different than the "open" ones ... I think they have a hub on one side.
While you have it all apart, have a good look at the spider gears(#4), thrust washers(#3,19), pins(#5,6), lock pin (not shown?), and clutches(13,14,15,18). Pick up a bottle of friction modifier, unless you are refilling with gear oil specifically designed for limited slip differentials.
Oh yeah ... get 10 new copper washers and a housing gskt as well. How's the pinion seal?
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Ford 9" question bonuts Transmission - Rearend 1 08-25-2003 07:03 PM
ford 9" 28 or 31 spline kid Transmission - Rearend 1 05-26-2003 07:32 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
