Ford 9" Axle Issues - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-28-2013, 12:30 PM
big gear head's Avatar
High Performance Rear Ends
Originally Posted by S10xGN View Post
D@mn, ya'll are scaring me now. I have a set of CAChassisworks triangulated 4-link brackets to weld on a completed axle. How can I check for trueness after welding it? Can I ASSume putting the axle in and checking for rolling resistance would be enough?
Russ
The best way to check the housing to see if it's straight is to install a housing fixture.
  #17 (permalink)
Old 03-28-2013, 07:45 PM
prostreet6t9's Avatar
Differential/Driveline
Russ
After you get it all mocked up and know exactly where the brackets are gonna go.. I'd just strip the housing down and take it to someone with a jig. It can save you money and A LOT of hassle in the long run.
It shouldnt be too spendy if you take them a bare housing.
  #18 (permalink)
Old 03-29-2013, 10:35 AM
S10xGN's Avatar
Gotta love a turbo!
If you're talking about a narrowing jig, I do have a bud with one. Is it safe to tack the brackets on first?
Russ
  #19 (permalink)
Old 03-29-2013, 10:39 AM
S10xGN's Avatar
Gotta love a turbo!
Hey Shane,
Couldn't help but wonder (looking at your handle), are you related to the "Robert Zildjian" who just passed away? He had a company that mfg'ed cymbals in MA.
Russ
  #20 (permalink)
Old 03-29-2013, 12:22 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey Shane,
Russ
Not related, I used to play drums in High School and used Zildjian brand cymbals and my username is a handle I have used for many years. Since I don't play anymore I should really update it at some point. But I didn't know he passed away.
  #21 (permalink)
Old 03-29-2013, 12:29 PM
Listen and Learn
Wiki Edits: 7
This past weekend I started to narrow and fix the offset of my 8.8 that is going into my cutlass. The driverside tube was rather bent. What is the best way to fix?, heat and cool rapidly on the long side to get it to pull in? I've attached a pic. Is it a big deal? Probably at least 1/4" off.
  #22 (permalink)
Old 03-29-2013, 01:27 PM
Russ
Yes a Narrowing jig. If you just tack just enough to hold the Brackets in place you will be fine.
  #23 (permalink)
Old 03-29-2013, 02:17 PM
Heating and cooling will probably bring it back around. It's worked many times for me. Be patient and do a little at a time. It takes a while to get it where you want it. Try to figure out where it is bent and work on that area the most.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (03-30-2013)
  #24 (permalink)
Old 03-30-2013, 09:40 AM
S10xGN's Avatar
Gotta love a turbo!
Oookay... I have welded two sets of leaf spring perches to both an 8.8" and a 9" housing and never had a problem. I usually just slip the axles in and feel for any abnormal resistance. So this is unacceptable by "normal" standards?
Russ
  #25 (permalink)
Old 03-30-2013, 09:46 AM
Welding something to the tubes doesn't bend the tubes a lot. Usually it's about 1/8 inch. Sometimes this isn't enough to cause a problem. I've seen some that were as far off as 1/4 inch. It's always a good idea to check after welding. Warped tubes can cause problems with wear on the axle splines and in the axle bearings. I've seen one that was off far enough to caused a Power Trax locker to break.
8.8" Ford axle question... S10xGN Transmission - Rearend 6 09-28-2012 10:56 AM
8" Ford - Axle concern michaelbc5 Transmission - Rearend 2 05-22-2007 12:59 AM
Ford 9" rear axle crownver Transmission - Rearend 5 01-24-2006 07:25 PM
9" Ford Axle seals? kevkoracing Suspension - Brakes - Steering 12 08-20-2003 01:24 PM
axle removal- ford 9" stea Transmission - Rearend 2 04-12-2003 01:07 PM
