Ford 9" axles in a 10 bolt Chevy rearend. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2008, 11:54 AM
Hi!
Is there anyone who had put a Ford 28 splines axle in a GM 8.5" (73-77)housing??
I did a quick measuring and find them very similar, diameter and type of splines.
If it works it should be a nice rearend eliminating the C-clips and a popular width if using two fullsize 28 inch long Ford axles,the total axle width should be around 57-58 inches.
Please correct me if Im wrong// Best regards RP.
Old 12-13-2008, 01:20 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I think in the street stock classes at our local racetracks they are common to use using GM axles tubes that are three inches in dia.
Ford tubes are three inches as well so weld on the ford ends and you got bolt on axle retention.
You can also weld on your own threaded snout and hub assembly to make a fully floated axle assembly that requires no c clip. Using the steel drive hubs though because i would thing the aluminum one most circle trackers use are limited in life on the street.
Old 12-14-2008, 12:26 PM
Sounds like a waste of time and effort.
C clip eliminators are readily available for the GM axles.
Stock Ford axles are not that strong, even if you can make them fit. and the wheel pattern will still be wrong too.
Aftermarket HD axles with C eliminators are the best bang for the buck and no hassles and messing around.
For $3-400 you will have a drop in situation with plenty of strength.
Chevy 10 bolt front end question Magikal Transmission - Rearend 1 12-09-2007 01:00 PM
Ford 9" rearend conversion donlp Transmission - Rearend 6 09-02-2007 12:23 PM
8.5 10 Bolt Chevy Info Needed jsteve068 Transmission - Rearend 6 09-26-2005 04:09 PM
10 bolt 7.5 to ford nine inch big455 Transmission - Rearend 4 10-28-2003 07:34 PM
Chevy 10 bolt I.D. hoghead? mikesminor Transmission - Rearend 6 03-05-2003 01:56 PM
