Ford 9" Bolt Pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2009, 04:59 PM
Can I change the 5" on 5" to 5" on 4.5" ?
Old 09-03-2009, 07:03 PM
BOBCRMAN@aol.com's Avatar
I used to do these back in the day. You have to weld a filler into one of the bolt access holes. Use machinable weld. Then you can change bolt pattern in a Bridgeport with an indexing fixture or drilling jig and correct drill bit for whatever stud you plan on using.
SBC Starter Bolt Pattern, Patterns? 63ChevyII Engine 13 09-21-2012 09:43 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Did Chevy change the exhaust manifold bolt pattern on small blocks? STATUTORY GRAPE Engine 7 05-13-2005 06:34 PM
351 Cleveland tranny bolt pattern?? voodoosurfer Transmission - Rearend 6 05-10-2005 08:33 PM
14 10.5" bolt chevy VS 9" ford Trav Transmission - Rearend 4 09-01-2003 08:49 PM
