Ford 9" brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2002, 01:22 PM
Don Meyer's Avatar
Post Ford 9" brakes
I have a Rolls Royce that I am installing on a GM frame. I have the large GM discs on the front(12") & a 9" rear w/11"x2" brake linings. Are the rear drum brakes sufficiant for a car that wts aprox 4400 lbs.(it wts 4800 now but, the Rolls motor is 400 lbs heavier than the rolls).......if required are their larger brakes drums I can install by changing the backing plates. thanks guys ,Don
Old 06-15-2002, 02:28 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
Don, actually 11" brake is pretty big to begin with. I wouldn't worry about it because the rear brake only does about 10% of the braking.
JB
Old 06-15-2002, 02:38 PM
FASTFORD's Avatar
Post
just my 2 cents, disc brakes are better so if u want to upgrade, look for a rear disc set up. good luck & let us know what works for your project.
Old 06-16-2002, 11:04 AM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
Post
Go to your local ford dealer and tell them that you want the rear disc brake set up for a 97 Explorer I think the kit number you want is M2300-g it comes with everything you need to make it disc
Old 06-26-2002, 04:23 AM
Don Meyer's Avatar
Post
thanks everyone - Lou, I going to the Ford dealer today to see if it's a bolt on...thanks
[ June 26, 2002: Message edited by: Don Meyer ]</p>
Old 07-16-2002, 04:41 PM
Don Meyer's Avatar
Post
Lou - I sent you a private message....Don
