Not sure of your dimensions. I was only aware of 2 sizes for flanges - big and small bearing. Bearing being axle. The backing plate mounting holes from the explorer are identical in pattern to a 9 inch large bearing flange and requires little work to make it fit on the small bearing flange. My housing has the small bearing flanges which came off of a late 50`s truck. Hope this helps. Roger
