Is this a ford 9" diff housing or did i get ripped? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2013, 05:39 AM
Old 12-01-2013, 07:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Looks like one to me..
Sam
Old 12-01-2013, 01:05 PM
big gear head's Avatar
High Performance Rear Ends
9 inch is the diameter of the ring gear and has nothing to do with the housing size. That looks like a 9 inch housing to me. That is the one with the long tapered center, which is the stronger one. It also looks like it may have the smaller 28 spline axles.
Old 12-01-2013, 03:13 PM
Thanks just got worried I bought the smaller 8"
It has 28 spline axles small ford bearings and tapered axle tubes 3.5" and taper to 3"
And was outof a coil spring setup
Old 12-01-2013, 03:50 PM
Does it have the axle tubes that are flat on top? If it does then it's from a big car, probably a Lincoln or Mercury.
I've never seen one of those housings with the small axle bearings.
Old 12-01-2013, 04:06 PM
Yes tubes are flat on top smooth back housing with dimples
Old 12-01-2013, 04:11 PM
Cost us a fortune to do cars up in Australia I paid $400 for this housing now need to spend over 3grand on it
To get large bearings ends wilwood brakes and 35 spline axles and centre. .
Because we have to buy everything from usa.
Old 12-01-2013, 04:20 PM
Yea, that would suck. I bought complete 9 inch rear ends around here for years for $25 to $50 each. The last few that I bought were $100.
ford 9 diff
9 3/8 lincoln diff in 9" housing. Studebaker Transmission - Rearend 2 10-27-2012 08:07 AM
Urgent drum identification help needed-Ford 9" diff! turbovanman Suspension - Brakes - Steering 11 09-20-2012 07:15 PM
8" Ford diff leaking around pinion nut Curmudgeon29 Transmission - Rearend 5 09-05-2011 09:15 AM
ford 9 inch housing 60 3/8" wide eatonde Transmission - Rearend 5 02-05-2009 02:10 PM
ford 9" rear housing for 70 camaro richrat Transmission - Rearend 1 05-03-2003 11:56 PM
