These are the rears as you asked. The fronts are on the back side.
![]() ![]() ![]() ![]() Either way works fine - if you can figure a way for that e-brake cable to run. I did mine in the front so I would have a good run without a sharp bend. You just swap the parts side to side. Dave W |
I'm running a Ford 9 inch on my 56 Ford truck. I did the conversion using a kit and GM Cadillac calipers. My calipers on at the 10:00 oclock postition toward the rear of the wheel. No problems with braking or ebrake. Not sure if it matters if the caliper is front or rear?
| 60 Galaxie disc brake upgrade | nottooold13 | Suspension - Brakes - Steering | 5 | 07-23-2007 01:43 AM |
| gm 14 bolt disc brake question | rock on | Suspension - Brakes - Steering | 2 | 01-03-2007 05:16 AM |
| One more oddball disc brake conversion question | powerrodsmike | Suspension - Brakes - Steering | 5 | 10-06-2006 12:02 AM |
| spindles on ford disc brake swap for 62 t-bird | wildnickels | Suspension - Brakes - Steering | 3 | 03-20-2006 04:47 AM |
| converting 9" ford rearend with 4.75 b.c. to disc brakes | CarMazed | Suspension - Brakes - Steering | 1 | 02-04-2006 11:40 PM |
