ford 9'' with disk brakes - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-07-2007, 09:43 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by new_rat_rodder
this is dumb i've learned alot about 9'' rearends but my question has yet to be answered
Sorry you got overlooked. X
57 1/2 inches wheel to wheel on all 57-72 Ford cars and pickups,
Some 78-79-80 Lincoln Versailles, Granada, Monarch with disc brakes.
car type is an easy bolt in 4 1/2 inch bolt circle, pickups springs are on top, have to be changed and the pickup bolt pattern is 5 1/2 requires redrilling to 4 1/2.
This should be 8" narrower than what you have.
The discs are popular and nice and showey, but the drums will stop very well, especially those big 11 inchers from trucks.
By the way axles are easy to get. All 28 spline small bearing axles are the same between 9 inch and 8 inch from Granadas, etc.
There are 3 different wheel bearing sizes, but that is irrelavent to your useage.
  #17 (permalink)
Old 02-07-2007, 10:00 PM
well thank you xntrik, i found a 9'' out of a pickup it should work. i should have done my research before buying the rearend out of that merc. maybe i can still use the disks from it so its not a total waste.
  #18 (permalink)
Old 02-07-2007, 10:23 PM
xntrik's Avatar
Check the bolt diameter on the backing plates, and the dimensions between the bolts. Some will, and some won't. Then you have to watch out if the wheel flange is too far from the housing end. They vary about .300 if I remember.
  #19 (permalink)
Old 02-07-2007, 10:34 PM
xntrik's Avatar
check the tag under a bolt to see what you have.
If you ever run across a pickup in the yard, and the door code says something like 31A.... instead of just a number or letter, you have a 31 spline posi gear ratio A.
  #20 (permalink)
Old 02-16-2007, 02:22 PM
tub 57 chev
I am looking for the thread where 57 chev was tubbed He did a good gob. Thanks
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Help with 9" ford rear brakes 1947chevypanel Suspension - Brakes - Steering 3 07-25-2006 10:29 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Disk Brakes for 3/4 ton 1966 Chevy P.U. big_daddy6464 Suspension - Brakes - Steering 4 10-21-2003 03:12 PM
