Ford 9" Gear Pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 09:41 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Someone(me) borrowed a pinion shim from it and I'm putting it back together and checking things over because I wanna take it with me as a alternate if the track conditions warrant it. This is a well used set. I mean well used like about 100 nights of circle track racing at least. Can a good pattern even be established on a set with several thousand laps on it? What direction does this thing need to go? Backlash is .012
ID:	54585   Click image for larger version
Old 04-22-2011, 08:12 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Looks good to me.
Rich
Old 04-24-2011, 12:24 AM
It's tough to see, maybe a little more force on the ring gear when you turn the pinion. At first glance it looks like the ring needs to come closer to the pinion, but tough to tell.
Ford 9" Bolt Pattern fredbaker Transmission - Rearend 3 10-15-2009 04:34 PM
Ford 9" Bolt Pattern fredbaker Transmission - Rearend 4 09-05-2009 12:48 PM
Ford 9" Bolt Pattern fredbaker Transmission - Rearend 1 09-03-2009 07:03 PM
Ford 9" lug bolt pattern sparkyct55 Transmission - Rearend 2 04-17-2009 10:36 PM
ford 9" 4 3/4 lug pattern the dan Transmission - Rearend 11 10-18-2007 06:40 PM
