Ford 9 Inch 3rd Member Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2010, 09:58 PM
My79Ford400ciF1504x4's Avatar
OK, so I have this 3rd member, I think its a trac loc / limited slip? Here are some pictures, but how would you tell if its a limited slip or something like a locker? If someone could tell me what this is it would be a lot of help. Thanks.
ID:	48739   Click image for larger version
ID:	48740   Click image for larger version
ID:	48741   Click image for larger version
ID:	48742   Click image for larger version
Old 10-08-2010, 06:18 AM
You could take it apart in 10 minutes and know for sure. I've never had a Ford clutch type limited slip apart so I don't know what they look like. Its not a Detroit locker because they don't use pinions, and you can see a pinion cross shaft thru the side view.
Probably doesn't make any difference though, since there's a high likelihood the whole thing is junk. I've never seen a 9 inch third member with that much visible damage that didn't also have a crack in the casting where the pinion nose bearing rides. That you could grind up that much metal without anything getting inside the differential housing itself would be real unlikely. Bearings would obviously be shot too, and that pretty much covers every major part of the entire assembly.
Best I can tell, it looks like its come from something with 31 spline axles. If you're looking for something to go in a 79 F-150 4x4 like your screen name might suggest, you might have a real problem finding something used that will work. I had the same truck for about 20 years. One of the side gears split and chewed up the spline on one axle. That was in the first half of the 90's and even then it was near impossible to find anything used. 4x2 trucks used 28 spline axles. You couldn't just swap the 3rd member and axles from a 4x2 into the housing because there's a difference in the overall width of the housing itself. Ford wanted about $450 back then for one new side gear and one new axle. I'd be afraid to ask the price today, if the stuff is even available.
I had a complete 4x2 rear end with the same 3.50 ratio, so I relocated its spring pads and put it in the truck. In looking for parts, I'd talked to the owner of a big junkyard that specializes in pickups, and he said he usually had a waiting list of 10 or more people looking for the 4x4 rear end, and that he'd only get 3 or 4 trucks on average in a year with the right rear end. That was over 15 yrs ago, and I'd guess they aren't any easier to come by today.
Old 10-08-2010, 06:51 AM
big gear head's Avatar
High Performance Rear Ends
The pictures are not at the best angle to identify it, but it looks like the Traction Lock. The TL uses a special ring gear bolt with a 5/8 head and a hardened washer under the bolt. The side cover on the differential is raised to make room for the clutch pack. The left axle gear is split and half of the splines are in the gear and half are in the clutch hub. Check the side cover for cracks. These are very bad about breaking.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
16 spline 3.23 ratio keep or replace? 29Sean Transmission - Rearend 4 03-05-2008 07:39 AM
9" ford 3rd member strength? 68c10owner Transmission - Rearend 10 06-13-2007 09:45 AM
Ford 8 inch disassembly? pcoghlan Transmission - Rearend 22 03-02-2007 08:31 AM
Ford 8 inch Posi Clutch Pack sodas38 Transmission - Rearend 3 01-06-2005 08:51 PM
