ford 9 inch, axle spline count ID ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2012, 10:59 AM
hey everyone,I was wondering if anyone can tell me how to identify if an axel is 28 or 31 spline without taering it apart. Is there some outside marking that can tell you this? I believe it came out of a seventies pickup the tag reads2-75-9-844a which I think is ratio and ring gear size and whatever else.
Old 07-04-2012, 01:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ford Rear Axle Assembly Identification - Page 01 - FORDification.com
Hope fully this will help you puzzle it out..
Sam
Old 07-05-2012, 08:27 AM
big gear head's Avatar
High Performance Rear Ends
The only way that I know of is to remove an axle. The tag says that you have a 2.75 gear in a 9 inch rear end.
Old 07-06-2012, 07:36 PM
9 in axels
thanks for the info.I bought this rear end without really checking it out first.Found out its to wide for a model a.
Old 07-06-2012, 07:47 PM
Narrow it. Have a chassis shop narrow the rear end to exactly what you need. The 9 inch is one of the easiest rear ends to narrow because usually you can respline the axles that you have and use them again. I don't recommend this for a high performance car, but for a cruiser it's just fine.
How wide does the rear end need to be?
Old 07-07-2012, 08:17 PM
9 in rear end
I need it to be around 50 inches between backing plates.
Old 07-07-2012, 09:58 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Agreed but only if the axles are not tapered.
ford 9 inch axle spline count torquemonster Transmission - Rearend 15 06-09-2011 08:51 PM
Axle spline count question Soto Transmission - Rearend 2 12-11-2005 02:09 AM
Chevelle 12 bolt axle spline count JamesRS Transmission - Rearend 4 10-23-2004 10:21 PM
Is it possible to tell spline count from axle tag? Dubz Transmission - Rearend 7 10-13-2004 05:35 PM
31 spline 9 inch ford Manley Transmission - Rearend 5 10-17-2002 06:05 AM
