ford 9 inch bolt pattern conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2008, 07:15 PM
Last journal entry: 52 belair frame off
Hi guys. I got a set of 20inch wheels 5 on 5" bolt pattern. The rear end of the car is a 9 inch ford 5 on 4.5".I want to convert to 5 on 5"(chevy bolt patter). Is there anything else I have to change out besides the axels and drums.Back plate and breaks are new (original)
Old 01-27-2008, 08:18 PM
31 five window
Last journal entry: grill and rear end
I don't know about the width but Lincolns came with the 5 on 5 pattern so maybe the axles and brakes would work for you. I am sure somebody here knows more about Fords. Is it narrowed?
Old 01-27-2008, 08:22 PM
You could have it redrilled.
Shane
Old 01-27-2008, 09:09 PM
BlownBigBlock447's Avatar
Or if ya didn't want to redrill the axles and if you can handle an additional 1" or 1.5" spacer. I'm sure TopLine offers an adapter to go from 4.5" to 5", did find one that Trans Dapt sells...
http://store.summitracing.com/partde...5&autoview=sku
Old 01-27-2008, 09:25 PM
kleen56's Avatar
There is no way that a chevy axle will fit into the 9" Ford rearend. The 4.5" pattern is a Ford Mustang, Cougar pattern starting around 1960's and up. You may not have enough meat on the axle end to redrill a larger pattern for the Chevy 5" lug pattern. You could get some axles from an earlier Ford truck (1960-70's F100's) which came with the 5 on 5.5 axle pattern and were Ford 9 inch rear ends. Even then, that axle came with a a larger axle bearing then the one you have on your rear end, which would also need to be replaced. I hear expensive here!!!! That axle plate is then large enough that would be able to redrill it to the pattern and new studs put in. The backing plates are the same, I'm assuming your running drum brakes which would require the drums to have to also be drilled out to the new pattern. An adapter like mentioned above may work and is most likely the inexpensive way to go, but don't plan putting alot of pressure or punishment to the rearend with that combination because it won't take it. You might have problems with the offset causing the tires to stick out too much or rub. Might be easier to find other 20" rims and sell those Chevy pattern ones you have.
Old 01-28-2008, 08:43 PM
I do have drum brakes, and rear end is has not been modified ,but is more narrow than the stock one. I actually have approximatley 1.5" of clearance so i might use adapters. I'll look at my nearest pick and pull and see what i can find on the lincolns.
Old 01-29-2008, 07:58 PM
onebadmerc's Avatar
I need a bucket of arc sparks
The big Lincoln Mark V's and Continentals in the 70's had a 5" on 5" pattern. I had a 78 Lincoln Mark V that had a 9" rearend with disc brakes with a 5" on 5" pattern. I sold it to a guy who was putting it in his 38 Chevy and was glad it matched his front bolt pattern.
Old 02-01-2008, 07:54 PM
you would'nt happpen to know the axells spline and width was do you..
Old 02-01-2008, 08:18 PM
onebadmerc's Avatar
The axles were 31 spline count, I don't remember the width. I do know it was wide and and very heavy, the guy who bought it was having it narrowed down so it would fit in his car.
Old 04-12-2009, 09:04 PM
axle splines
The lincoln rear end that I got was a 28 spline. I think mine come from a 79 or 80. Hope it helps
Old 04-12-2009, 09:27 PM
techinspector1's Avatar
Wiki Edits: 326
Cheapest way out is adapters. I wouldn't use cast adapters though, too many horror stories. Use billet like these from Speedway....
http://www.speedwaymotors.com/displa...ign=GoogleBase
Old 04-15-2009, 09:27 PM
a new guy got you techinspector, who responds to year old posts all the time around here now. I go back 10 pages and see posts from a few months maybe.
Old 04-15-2009, 10:54 PM
Wiki Edits: 326
D'OH, thanks Scotto. Well, maybe someone else will benefit from the cast/billet difference.
Old 04-16-2009, 08:24 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Just to add a little help, ebay has sellers that sell them in pairs cheaper. Just look out for the billet 6061 aluminum adapters / spacers. When I bought some a year ago they were $50 + shipping a pair. Now they're on average $80.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
9 inch Ford disc kit 37Ford Suspension - Brakes - Steering 8 01-20-2004 08:51 PM
gm 10 bolt to ford 9 inch junkyardracin Transmission - Rearend 4 08-31-2003 09:05 PM
