Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9 inch to Chevy 4.75 pattern questions
Old 01-07-2006, 01:50 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
The cost of re-drill will depend on whether the shop is set up to do this kind of work (has a template, or dividing head setup). The other is which axle you have. Car or truck?. Some need a hole filled to redrill to 4 3/4". I used to have sections of cold rolled bar stock that I filled the holes with.
Chevy drums won't fit the Ford rear housing. Backspacing and center hole are wrong. You will have to redrill the Ford drums also.
