Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9 inch to Chevy 4.75 pattern questions
Old 01-07-2006, 10:03 PM
Infomaniac's Avatar
Infomaniac Infomaniac is offline
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
We change bolt circles in axles, drums, rotors wheels etc regularly in my shop.
Yes an indexing spacer is the tool to use on the mill.
We get 65.00 each to do a redrill. Don't need to plug unless the axle is only thick where the studs are now. If the hub is the same thickness all the way around we wiill just locate between existing holes.
Oklahoma is a bit closer than Indiana. LOL
