Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9 inch to Chevy 4.75 pattern questions
Old 01-17-2006, 10:28 PM
Onestreetrodder Onestreetrodder is offline
onestreetrodder
Axels & Brake shoes
3100 I used Moser axles,drilled 4 3/4. bendex 2 1/4 x 11" shoes, and Ford drums drilled to 4 3/4.
you may be able to have your Ford axles drilled.
The center hole in the Ford & Chevy drums are different..With Ford axles you will need to use Ford drums..
