Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9 inch to Chevy 4.75 pattern questions
Old 01-18-2006, 06:27 PM
39 chev 39 chev is offline
ford 9 inch to chev 4.75 pattern
Originally Posted by Onestreetrodder
3100 I used Moser axles,drilled 4 3/4. bendex 2 1/4 x 11" shoes, and Ford drums drilled to 4 3/4.
you may be able to have your Ford axles drilled.
The center hole in the Ford & Chevy drums are different..With Ford axles you will need to use Ford drums..
I drilled my 9 inch axles to chev bolt pattern [77 bronco 9 inch], but when I tried to put on my 8'corvette ralley wheels, they would not fit over the center of the axle.luckily I had a pair of new aftermarket ralleys that fit the ford axles.I was able to use the stock ralleys on the front, so itworked out ok for me.
