I have no idea what part you are talking about. the crush sleeve perhaps? For setting pinion bearings preload?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I wonder if he is referring to the copper washers on the studs that retain the third member.
This is what he's talking about. I'm using one from Strange Engineering (N-1910) that's very similar.
It takes the place of the 9" crush sleeve using multiple thickness shims between two billet end pieces. Add/remove shims to achieve the correct rotational torque. I torqued my pinion nut to 175# and began checking rotational torque. When I had the correct numbers, I lock-tighted the nut. I'm not sure what my final pinion nut torque is but it is substantial! It's called a solid adjustable pinion spacer I think. |
Your very welcome. I was a little confuse when I got mine, called Strange and got all the info i needed to set it up correctly. Typical of any rear setup, lots of disassembly and checking.
Larry |
| Ford Muscle..what's wrong with them? | tm454 | Hotrodders' Lounge | 41 | 11-20-2006 12:37 PM |
| 9 inch ford rear end | chi-town-st-racer | Transmission - Rearend | 13 | 02-22-2006 09:48 AM |
| Wanna Talk Cars "Fords" | 66Falcon | Hotrodders' Lounge | 17 | 10-01-2005 05:29 AM |
| 10 bolt 7.5 to ford nine inch | big455 | Transmission - Rearend | 4 | 10-28-2003 07:34 PM |
| disc brakes for ford 9 inch | Beedog69 | Suspension - Brakes - Steering | 6 | 06-04-2002 03:18 PM |
