i have an 81 camaro and am going to get a big block eventually and would liek to get a ford 9 inch. i found one that is from the 70s and is 57 inches wide. i talked to someone about a 9inch and they said certain years would bolt right in with minor modifications. so i was wondering if this would be one of those
Your rear is around 60" flange to flange so with the correct wheel you should be OK. I had a 77 Nova that has the same rear as your Camaro and I used a 9" from a 69 Mustang. All we did was cut the pads off and weld new ones on to put it in the Nova.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
