Ford 9 inch NASCAR ring and pinion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2011, 09:15 AM
96lt4c4's Avatar
I know the owner of a local machine shop. I was talking about the Ford 9 inch in my Camaro. He mentioned that he has been getting used NASCAR ring and pinions and that he would sell me one in the ratio that I need for about $150.00. Wondering if anyone has experiance with these? Are they quiet?
Old 10-16-2011, 09:53 AM
MAYBE ... but I doubt it.
The ring and pinions are set up without any regard to noise ( RACECAR ).
Then replaced after each race.
Ford has not made any 9 inch Ford gears in over a decade. Most of the race shops use Richmond Gears ... made in Liberty SC. I have a few friends who work there.
For a street car ... a factory Ford gear is much preferred ... by myself. They always run a lot quieter. NOS ones show up on eBay every so often. That is where I got my last gear set.
DEUCE ... Moderator
Old 10-16-2011, 10:11 AM
96lt4c4's Avatar
DEUCE ... Moderator
I am looking for a quiet gear. I have seen pictures of some that have a REM coating on them. They almost look chrome.
Old 10-16-2011, 11:47 AM
Search ebaymotors for Visteon and you will get lots of used NASCAR gear sets. Visteon used to be part of FOMOCO but I think its a separate company now. They are good gears but I dont have any idea if they run quiet or not as I have only used them is race cars because of the odd ratios that are available.
Old 10-16-2011, 09:48 PM
prostreet6t9's Avatar
Differential/Driveline
The quietest gears on the market are the Ford Racing sets.
Old 10-17-2011, 07:12 AM
96lt4c4's Avatar
I have heard that those were reboxed Motives. I just put a set of Ford Racing gears in a 8.8 Mustang and the instructions in the box were USA Standerd gear. The instruction book was the exact same booklet as what comes in the Yukon gear box, just USA Standerd gear printed on the front instead of Yukon...
Old 10-17-2011, 07:19 AM
Some hi end nascar gears are lightened up a whole lot and this is ok for their use but not as good if you ever used the gears for dragging especially if using slicks on a preped launch pad at the strip. This is just a guess by me but Id think the heat treat would be more to absorb impact than for long life or quietness much like how pro drag gears are made.
Old 10-17-2011, 07:22 AM
96lt4c4's Avatar
How about US Strange/Gear or US gear. Do you have any experiance with those?
I think they are the same thing.
Old 10-17-2011, 07:31 AM
SSedan64's Avatar
Drag only Gears are much softer to absorb launch Impact as said above, they aren't recommended for Street use.
Did you figure out what was wrong with the Yukon gears? Pinion Wobble?
I have a set of Visteon 3.90 gears, I bought a while back, came out of one of Dale Jr.'s DEI cars. They have the Remedd treatment, look about like Chrome/Polished, very nice quality.
I'm not going to use them, PM if interested.
Old 10-17-2011, 07:59 AM
96lt4c4's Avatar
Yes, the Yukon gear is bad. I am sending it back. I used all new bearings, and a brand new pinion suport and it was wobbling. So, I had an old support with used bearings and an old pinion still in it. I checked it and it was dead straight. I took it apart and put the old bearings on the new pinon and set it up in the old support so that the only thing that could wobble was the pinion and it still wobbles .001". Thats not acceptable in my book. The snout shows uneven wear marks were it is moving from side to side in the case bearing, and this is just from me spining it by hand checking the pattern. My back lash was all over the place and so was the pattern. Like I said in my other post the Motive that I just had in there setup a lot easier and did not have run out, back lsah was also the same all the way around the ring gear. The Motive was just really noisy, and had been run with my bad axle. I bought it from Summit, I knew they would take it back so I went ahead and got a new gear. I bought the Yukon that cost more money because of thier reputation thinking I was getting a better gear. Guess not....Now I am on the hunt for another R&P. I may have end up trying every brand before its all said and done....
Old 10-17-2011, 10:07 AM
96lt4c4's Avatar
Is it just me or can you no longer get Ford Racing 9 inch ring and pinions?
Old 10-17-2011, 10:39 AM
The Ford gears are NOT a Pro Gear. They are perfect for the street.
Old 10-17-2011, 10:46 AM
Yes You can buy them. Check the Ford Motorsports web site or any of the ring and pinion suppliers. They are not a Motive gear.
http://www.ringpinion.com/ProductDet...nd=Ford_Racing
In a quick search thats the closest I could find for you.
Old 10-17-2011, 01:13 PM
Thought I rem. seeing Ford Racing r &p in the Summit catalog. Looked on line and they have them only for the 8.8 in. Kinda weird.
Old 10-17-2011, 01:33 PM
SSedan64's Avatar
There may have been a supply problem with the 9" gears, Visteon was in Chapter 11 back in 05.
Some Gear Info >> http://www.allfordmustangs.com/forum...nce-gears.html
http://www.google.com/url?q=http://w...QS_I_fg9GeHf6w
9 inch ring pinion installation kit? turchiac Transmission - Rearend 6 02-04-2011 05:41 PM
FORD 9" Ring & Pinion solidaxel Transmission - Rearend 11 06-07-2010 05:08 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 10:17 AM
Which Ring & Pinion Kit? Ford 8.8" nightrain_rod Transmission - Rearend 0 12-03-2003 11:48 PM
ring gear numbers-9 inch ford mike bryan Transmission - Rearend 3 04-21-2003 03:20 PM
