Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9 inch outer axle Bearings
Old 06-22-2010, 09:37 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
In my limited experience, I've found it almost impossible to predict which Ford rear end might be under a particular car or truck model. Throughout the years, there was an awful of of "use whatever we've got left" mentality applied at the Ford assembly plants. Granted, there are some makes/models where it is "more likely" to find certain rear ends, but you almost need to peek under every single one of them because they just might have exactly what you are looking for. Or in the alternative, the rear end you were expecting to see just might NOT be the one you find. That is why the site cobalt provided is so important...so you can make a quick visual ID as you are inspecting potential donors.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
