ford 9 inch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2006, 08:32 PM
leldai73's Avatar
Its just metal,you're the boss
im trying to graft a 9 inch into my 1984 monte carlo ss and im going to have to have my axles re-drilled for the correct 5 x 4 3/4 bolt pattern, but i noticed the axles i have, 31 spline from a 1979 F-150, have an access hole for the bolts holding the backing plate on. i am wondering if it is possible to have these particular axles re-drilled or if the acess hole is going to make it impossible. I cant get ahold of the guy im going to have redrill everything until after the holidays and i would like to know sooner than that. any help would be greatly appreciated. and a merry christmas to all.
Old 12-24-2006, 09:23 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
The guy thats doing my 9" axles says its not a problem as long as theres only 1 hole. I think they weld up the hole or something.
Old 12-25-2006, 07:44 AM
leldai73's Avatar
thanks alot, im sure glad to hear that, wasnt looking forward to dropping the extra cash for new or atleast different axles.
Old 12-26-2006, 11:41 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I have seen many redrilled without welding the hole. NO problems.
You will probably have to have the flange diameter reduced in a lathe depending which brake drums/rotors you are using, unless you are using the truck brakes.
Old 01-02-2007, 05:15 PM
leldai73's Avatar
i'm planning on using disk brakes from an exporer...if i can get all the stuff together.
Old 01-02-2007, 05:50 PM
The Maintenance Geek
So you're going to need to have the rotors drilled for
the same 5 on 4 3/4" as well, as the Exploder has
5 on 4 1/2"...
Just a heads up...
K
Old 01-02-2007, 07:05 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
ford 9 inch
I drilled my 77 bronco axles to 4 3/4 bolt pattern and didnt have any problem with the access hole.
which 9 inch Ford to use dbell Transmission - Rearend 3 02-28-2006 08:17 PM
9 inch ford to 56 chevrolet ray bob Transmission - Rearend 3 01-27-2006 04:19 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 08:29 AM
9 inch ford setup question Eric327 Transmission - Rearend 8 01-18-2006 09:31 PM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 09:47 PM
