A Ford 9 inch Question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2007, 11:16 AM
estrellam's Avatar
Don't be a fool wrap you tools
I have a 1960 31 spline ford nine inch I'm having a lot of trouble getting the passenger side axle out. Can anyone help?
Old 01-19-2007, 11:22 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Bent tube is real common. Burrs on the axle end is another common problem. they are somewhat a tight fit.
Try a slide hammer or take the other side out and hammer on a long steel rod to drive out the axle from the carrier end.
Old 01-19-2007, 11:24 AM
estrellam's Avatar
relpy
I have a slide hammer but I just use it for dents. How do you set it up to pull a axle??
Old 01-19-2007, 11:37 AM
Mine has a three jaw thingy that goes on the end. I then wrap a zip tie around the jaws so they don't slip.
Have you tried using beating on the inside flange of the axle with a soft faced dead blow hammer. Get one about 3 pounds or so. Whack it good.
Old 01-19-2007, 11:39 AM
poncho62's Avatar
Wiki Edits: 5
You can also use a piece of chain as a slide hammer. Bolt one end to a stud and snap it tight....works the same. although a weight on it is more effective.
Old 01-19-2007, 09:48 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Put the brake drum on inside out with the nuts on about 3-4 threads, flat side toward the drum. Use the drum as a bang-puller. It will pop right out....... if you have the 4 retaining bolts out......LOL
Old 01-20-2007, 09:20 PM
estrellam's Avatar
The problem solved.
I finally got it out but it was really seized on there. What I had to do was tie a chain to one end of the rear end and another chain to the axle. Then I just pulled it out with my truck. The axle wasn't bent or anything.
Old 01-20-2007, 09:39 PM
If memory serve's me right ? The bearing is pressed ontoo the Axle . Meaning bearing should have come off with the Axle ? Inspect bearing for Discolouration . If I remember correctly ? They can be kinda tuff , if bearing gett's Lil hott . Tend's too bake gear lube around outer race . Doesnt wanna come out of Axle houseing . Sign of Heat possibly . Be Nice too the Bearing , or make new Freind's, with a New bearing . Bearing did come out on the axle, Didnt it ? Sean
Old 01-20-2007, 11:51 PM
xntrik's Avatar
Is your seal inside or outside the bearing? Just curious.
Old 01-21-2007, 05:57 AM
How are the splines? A traction lock has the clutch pack on the left, if the splines are twisted it won't pass through the clutches and side gear easily.
Old 01-21-2007, 12:23 PM
fast68's Avatar
likes chevy trucks & boobies
pasenger side is harder to yank out yes
how i do it is i put a chain on one of the lug studs with a lug nut and then i yank on it really hard
had to do this on the 77 f150 4x4 not too long ago, its a 31 spline 9" with 3.50 gear
we broke the housing at the pinion bearing support
these housings are pretty weak, cant take the load in a 4x4, thin casting around the bearing,
whoever says 9" are strong dont know very much about these axles,
10 and 12 bolts and dana 44/60 dont break like this nor other axles
good luck
which 9 inch Ford to use dbell Transmission - Rearend 3 02-28-2006 08:17 PM
9 inch ford to 56 chevrolet ray bob Transmission - Rearend 3 01-27-2006 04:19 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 08:29 AM
9 inch ford setup question Eric327 Transmission - Rearend 8 01-18-2006 09:31 PM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 09:47 PM
