ford 9 inch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 12:10 PM
I currently have a ford 9 inch that currently has a single track carrier, can i buy a posi clutch trac kit and install inside my carrier or do i have to buy a all new carrier?
thanks
Jon
Old 09-20-2012, 01:15 PM
big gear head's Avatar
High Performance Rear Ends
You can get a Power Trax locker and put in your differential case. That's the only thing that you can use in it. They jerk and pop some and are not very smooth. I recommend the Yukon Dura Grip. This is a very strong clutch type differential that works well on the street and strip. There are 2 versions available. The mild one has 2 springs in it and the agressive one has 4 springs. I like 4 springs. These are also rebuildable if you ever wear it out.
A Ford 9 inch Question. estrellam Transmission - Rearend 10 01-21-2007 11:23 AM
ford 9 inch question leldai73 Transmission - Rearend 6 01-02-2007 06:05 PM
yet another ford 9 inch question leldai73 Transmission - Rearend 9 12-29-2006 10:05 PM
question about a ford 9 inch 38 old coupe Transmission - Rearend 3 04-15-2006 08:40 PM
Ford 9-inch question? cabrio Transmission - Rearend 1 02-09-2003 04:19 PM
