ford 9 inch questions/ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2008, 10:21 PM
OK I got this rear end from a 81 f100 at the just yard
on the center section/case it has a round tag that looks like a clock face with the numbers 13576 on it, in clockwise order.
there is a tag that reads 0F2
there is also a large 69 on it and a symbol that looks like 2 c's with an M shape over the top like this M
(c
the ID tag had been snipped off but what was still there showed that it started with a 2 (prolly no help)
on the pinion/yoke support there were several diff. numbers. 2 in sets and 1 single
1). D2SW-G
2). 2649
3). 4
anybody know if this is origonal for this truck or did someone put it in??? Any info would be appreciated???
Old 12-01-2008, 10:33 PM
SSedan64's Avatar
May find some Info here.
http://www.fordification.com/rearends-ford07.htm
Old 12-03-2008, 10:52 AM
numbers
ok guys I funially got it pulled apart this morning, and here's what I got.
ring gear: 9A D AW 4 10 A 16-4
Carrier: C6AW-4205-B MC6 3
center section: C7AW-E 69
Any info on this would be appreciated. I'm pretty positive its a 280 ratio, unless ford does something that I don't know about, cuz I am a chevy guy!!!
Is the 69 stamped on it a casting year??? somebody cut the tag off so this is the best I got to work with.. Please help!!
Old 12-03-2008, 10:53 AM
oh axles
31 splines large bearing
Old 12-07-2008, 08:51 AM
Originally Posted by eatonde
ok
Please help!!
Count the teeth.
Divide the big number by the little number.
Old 12-07-2008, 09:33 PM
Ratio???
I know about the ratio and how to find it and what it is...... 2.75.... If my thread hadn't got hijacked by cyber brat with all his mumbo jumbo, mabey you would have caught it when I said it was a 280.... I mis counted... there were only 44 teeth on the ring not 45....
Any way does ayone know any info on how ford does thier casting #'s mainly for date and what it ORIGONALLY came from. the length flange to flange from the outside edges is 60 3/8's" leaf pad to pad is 47" apart and shock mounting bracket is 35.5" apart. All measurements were taken from outside edge to outside edge.....
Old 12-07-2008, 09:37 PM
my thread
No dis-respect, but can we please try and stick to the subject???
Cyber-rat, I know your questions are SOMEWHAT related to this thread but you keep askin so many questions that people are forgeting what the thread was started for..... This is where we use the term hijacked my thread. start a different one for your stuff
Old 12-08-2008, 07:17 AM
SSedan64's Avatar
(c
1). D2SW-G
2). 2649
3). 4
Thread did kinda get jacked there. See if post #2 by Techinspector1 about Ford's numeric system can help with the rear ID #'s. Hope this will help you out D.
460 Ford Opinion / Info
Old 12-08-2008, 08:07 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I removed the posts about Cyberats questions which is now in it's own thread.
I should have done this earlier, I apologize for not responding more swiftly
Old 12-08-2008, 10:17 AM
the tag's gone
The problem is that site uses the id #'s off the tag, and my tag is gone so its no help..... Alll I got is the above mentioned casting numbers
Old 12-08-2008, 02:37 PM
SSedan64's Avatar
Did you look at the 2nd post on this link about the casting #'s?
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
9 inch ford rear end chi-town-st-racer Transmission - Rearend 13 02-22-2006 09:48 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
10 bolt 7.5 to ford nine inch big455 Transmission - Rearend 4 10-28-2003 07:34 PM
disc brakes for ford 9 inch Beedog69 Suspension - Brakes - Steering 6 06-04-2002 03:18 PM
