Ford 9 inch rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2003, 12:22 PM
Nos's Avatar
Nos Nos is offline
Post Ford 9 inch rearend
ok gys .. here goes.. o have a 1965 chevy pick-up im restoring.. and even though its chevy .. do you think a 9 inch ford rear end will do good in my truck?.. the truck has a chevy 350/th-400 trans..and the 350 is modded.. its bored 0.060.. flat top pistons.. and had heads built from the machine shop ... headers ( dont know what kind .. thinking of buying new ones should be pushin 400 + HP .. hopefully.. still need a cam ) and i want to put an exhaust system on there.. ( perferbly flowmasters ).. but im wondering if this is a good rearend? and does it have posi or what would the gears be?? and i can get one right now for $50.00 .. is that a good price?.. and um.. how hard will it be to install?thanks in advance.. just wonderin! if thers anything else i should know please tell me ..
Nos
N|O|S
Old 05-19-2003, 09:20 PM
Post
The Ford 9" rearend is the Godhead of all differential assemblies. It is available in many different widths and gear ratios and parts are everywhere. Do your research and get the strongest unit that you can afford and is the right dimensions for your truck. Don't forget to have the axles redrilled to the Chevy bolt pattern.
Old 05-21-2003, 08:39 AM
Nos's Avatar
Nos Nos is offline
Post
or is there a better rear end out there for my truck? something that could bolt right in? with less hassel and with good gears or posi?
N|O|S
