Ford 9 inch swap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2011, 07:43 PM
67MercCat's Avatar
Junkyard Dogg
I have a 65 Thunderbird 9 inch rear end that I want to drop into my cougar. The width is fine (inch longer than my 8 inch) and I'm already familiar with the fact that I have to cut off and reweld the spring perches. My next question is this...
1. Should I have grabbed the driveshaft too, so the u-joints match? (my current driveshaft u joint housing proves to be too small and too long)
2. Where do I find a compatible yoke for my T-5 to 9 inch driveshaft (aftermarket or pick a part) ?
Thanks guys
Old 10-18-2011, 08:14 PM
327NUT's Avatar
Whomever builds your new driveshaft will be able to furnish the needed parts to adapt the T5 to the 9"
Old 10-18-2011, 08:23 PM
67MercCat's Avatar
Junkyard Dogg
oh I see, I wasn't familiar with how that's done. So the driveline company I use will be responsible for all that. It's my first time doing this so that type of info is greatly I appreciated.
Old 10-18-2011, 08:48 PM
31 five window
Last journal entry: grill and rear end
Having a drive shaft made as stated is the best way,but if you have one the right length NAPA sells cross over ujoints that will let you use your shaft with a different yoke.I have done this many times when putting a Ford 9" in a Chevy.
Old 10-19-2011, 09:50 AM
67MercCat's Avatar
Junkyard Dogg
cross over U joints? wouldn't that cause a balance issue?
Old 10-19-2011, 11:00 AM
327NUT's Avatar
You're worrying way too much about these things, call a good driveline company and tell them your application and they will build you a properly balanced driveshaft that will mateup to your 9" and T5.
Old 10-19-2011, 11:22 AM
techinspector1's Avatar
Wiki Edits: 326
You may not have what you think you have. According to what I read, the diff you have is a 9 3/8", not a 9". They were a heavier duty diff used in the largest, most powerful Ford cars. I have come across them before in hot rodding. There are no aftermarket parts available for them like there are for the 9".
copied and pasted from www.ford-trucks.com ....
'63-77 Lincoln, LTD, and Thunderbirds had 9 3/8 inch centers, housings were cut away at the gasket surface for ring gear clearance, one curved rib at the front top portion of differential, strong but poor selection of axle ratios.
copied and pasted from www.mustangandfords.com ....
It also has a different pinion support, with a C8AW-B casting number.
copied and pasted from http://automotivemileposts.com/tbird...fications.html
REAR AXLE CODES
1 - 3.00:1
4 - 3.25:1
5 - 3.50:1
6 - 2.80:1
A - 3.00:1 Equa Lock
D - 3.25:1 Equa Lock
E - 3.50:1
F - 2.80:1
Old 10-19-2011, 01:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Below is a photo of the Ford 9-3/8" rear end. The '65 T-Bird is said to have either the 9" or the 9-3/8" diff depending on the source, so it would be well worth your trouble to make sure before getting too far into it.
Old 10-21-2011, 05:48 AM
31 five window
No,the cross over joints do not cause a balance problem.They are correct about the 9 3/8" diff. I would do like tech and cobalt says and make sure you have a 9" because like it was stated there is no aftermarket support for the other one,only the 9". Hope this helps.
Old 10-25-2011, 10:16 PM
67MercCat's Avatar
Junkyard Dogg
thx for the heads up guys but its a 9 inch. the case doesn't look like that one with the curved rib and plug...its has straight ribs and big spring perches (which I cut off today) whats the next step? buying new perches?
Old 10-26-2011, 06:41 AM
Ford 9 inch
The 9 inch is the way to go, but be careful welding on the axle tubes, don't get them too hot and make sure the housing is square with the front wheels. There is nothing uglier than a nice looking car "dog tracking" down the highway..............pc
Old 10-26-2011, 08:07 PM
67MercCat's Avatar
Junkyard Dogg
yeah man thats so lame, I always wonder what caused the car to look like its drive crooked haha. I'm going to use the leaf springs as a guide (for straightness) and I'm going to remove the current rear end and place the 9 inch rear end housing on the plates, adjust the pinion angle using an adjustable jack stand and tack weld them to the housing.
As far as the welding, I've been told to weld 1 inch at a time and switch from side to side in intervals to get around the heat issue.
I went to the driveline company today and they told me to bring in my current shaft and they'll shorten it to go from my T5
Old 10-27-2011, 03:37 PM
Ford 9 inch
Hey, I would say you got it going on. We have done a bunch of those conversions and finally learned not to mess around with drive lines, its cheaper to pay somebody that has the proper equipment...good luck..pc
Old 10-29-2011, 10:37 PM
67MercCat's Avatar
Junkyard Dogg
Any suggestions for a 4X4 supply where I can buy some perches for a good price? I've been searching and haven't come up with anything reasonable....
Old 10-30-2011, 08:22 AM
Wiki Edits: 27
speedway ?
look in your speedway catalog or go to a trailer supply Co, The bigger ones have a lot of parts handy for fabbing rods , or a good steel supply co that has parts to build wrought iron fences, brackets drilled plates etc.
Ford 9 Inch Posi Swap 31fordcoupe Transmission - Rearend 11 11-06-2009 09:38 AM
9 inch ford G body rear axle questions, advantages STD spring, coil over eatonde Transmission - Rearend 9 01-21-2009 11:11 AM
ford 9 inch questions/ID eatonde Transmission - Rearend 10 12-08-2008 02:37 PM
Ford 9 Inch - Pinion Yoke Swap JC6715 Transmission - Rearend 9 12-03-2008 10:25 AM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
