-   -   Ford 9 Inch Yoke (http://www.hotrodders.com/forum/ford-9-inch-yoke-218884.html)
mbporesky 05-01-2012 07:24 PM
Ford 9 Inch Yoke
I recently had a 9 inch leak on me from the pinion. I change out the seal and it still weeps. The yoke had obvious indentations on it from where the seal sat. Should i replace the yoke. Could i have replaced the seal wrong?
Thanks
Mike
BOBCRMAN@aol.com 05-01-2012 07:39 PM
The yoke is probably worn too far. You can get a new seal and place a .060" or so shim in the bore to hold the seal out in a different spot. Get a "speedy sleeve" repair sleeve and press onto the yoke. Or get another yoke.
mbporesky 05-01-2012 07:44 PM
Sorry but do you know what size speedy sleeve i would need?
I never knew about them but thats a great idea
prostreet6t9 05-01-2012 10:17 PM
Look for part# 99181
That is your speedy sleeve that will fit your yoke.
