Ford 9 Inch Yoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2012, 07:24 PM
Ford 9 Inch Yoke
I recently had a 9 inch leak on me from the pinion. I change out the seal and it still weeps. The yoke had obvious indentations on it from where the seal sat. Should i replace the yoke. Could i have replaced the seal wrong?
Thanks
Mike
Old 05-01-2012, 07:39 PM
BOBCRMAN@aol.com's Avatar
The yoke is probably worn too far. You can get a new seal and place a .060" or so shim in the bore to hold the seal out in a different spot. Get a "speedy sleeve" repair sleeve and press onto the yoke. Or get another yoke.
Old 05-01-2012, 07:44 PM
Sorry but do you know what size speedy sleeve i would need?
I never knew about them but thats a great idea
Old 05-01-2012, 10:17 PM
prostreet6t9's Avatar
Differential/Driveline
Look for part# 99181
That is your speedy sleeve that will fit your yoke.
Do they make a shorter yoke on the 9" ford differential, or trans yoke grobb284 Transmission - Rearend 4 07-17-2009 08:57 AM
Ford 9 Inch - Pinion Yoke Swap JC6715 Transmission - Rearend 9 12-03-2008 10:25 AM
Ford 9'' yoke seal fat40 Transmission - Rearend 2 02-17-2008 12:21 PM
Ford 9 Inch pinion yoke length?? baddbob Transmission - Rearend 15 05-31-2007 11:40 AM
9 inch Currie Rear end...I need a YOKE!!! JasonSC Transmission - Rearend 3 09-15-2005 07:43 PM
