Ford 9" leaking on both sides of the pinion retainer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-20-2011, 12:14 AM
prostreet6t9's Avatar
Differential/Driveline
Originally Posted by adam83
oh crap... I dont know what pre load is...
Preload is how much effort it takes to turn the pinion yoke. It needs to be correct or you could end up with brg problems.
  #17 (permalink)
Old 09-20-2011, 01:20 AM
adam83's Avatar
Is this something I can easily F-up even if Im being careful? I've been watching videos on youtube to see what you're talking about, and it looks like I'll need a special wrench to hold the flange while I tighten/untighten the pinion nut? then I'll need a inch/pound torque wrench to make sure the preload is at a certain spec?
  #18 (permalink)
Old 09-20-2011, 06:46 AM
Irelands child's Avatar
I guess we need to eddicate you. Here is one of many on the internet. Some are good, others baaaaad.
http://www.ford-trucks.com/article/i...ear_Setup.html
Irelands child
  #19 (permalink)
Old 09-20-2011, 10:53 AM
adam83's Avatar
ok, so I skimmed it, but it doesnt get to the part about how to set preload on the pinion nut
  #20 (permalink)
Old 09-20-2011, 11:48 AM
You can put the pinion yoke in the vice to hold it. Set it in the vice with the yoke facing up and the pinion support below the vice so you can spin it. Just tighten the nut JUST A TAD TIGHTER than it was. When your done you want to be able to feel a SLIGHT drag with NO play in the Brgs.
Remove the 5 pinion support bolt's.
remove assembly.
remove pinion yoke and seal
Remove old o-ring
Clean the oil off pinion support and case
Install new seal.
Install yoke as noted above
Install new o-ring with sealer
Install assembly
Clean any excess sealer
I changed it for ya
  #21 (permalink)
Old 09-20-2011, 01:51 PM
adam83's Avatar
alright.. if I dont post back, it's because everything went all wrong and I had a major heart attack
  #22 (permalink)
Old 09-20-2011, 03:42 PM
I will call 911 for ya Kidding
If you run into problems post back and we'll get it figured out.
8" Ford diff leaking around pinion nut Curmudgeon29 Transmission - Rearend 5 09-05-2011 09:15 AM
Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! artillerystevens Transmission - Rearend 6 04-10-2011 04:57 PM
Ford 9" pinion retainer bolt pattern crazyj Transmission - Rearend 0 10-11-2009 08:24 PM
Ford Nine Inch - Pinion Retainer Leak JC6715 Transmission - Rearend 14 04-09-2009 11:37 AM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 10:17 AM
