Ford 9" leaking on both sides of the pinion retainer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2011, 10:17 PM
adam83's Avatar
There is a leak coming out from under the pinion retainer, that piece with the 5 bolts. There is also a leak on the other side from the seal were the flange comes into the Pinion retainer. So basically both sides of the pinion retainer are leaking.
This is my first time doing this job, so I've been researching online. I've seen a lot about replacing the pinion retainer seal, but none on the o ring replacement. Is it pretty simple?
Am I mistaken about there being 2 seals here?
Old 09-16-2011, 10:18 PM
adam83's Avatar
btw I'm getting the part names Im using from this diagram:
http://www.angelfire.com/co3/vintage...ome/fo9dia.jpg
Old 09-17-2011, 08:22 AM
S10xGN's Avatar
Gotta love a turbo!
You can replace the O-ring by removing the driveshaft, the 5 bolts, and then pulling out the pinion carrier. Just don't lose the shims, they set the pinion depth and are critical for longevity.
Russ
Old 09-18-2011, 04:54 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Is your differential the same as the picture you posted? My Nova has 9" with the large Daytona carrier, and no "O" ring. I see the picture has the carrier with a built-in bump stop.
Semper Fi
Old 09-18-2011, 08:39 PM
adam83's Avatar
I'll take a picture and post it.
Old 09-18-2011, 11:21 PM
adam83's Avatar
Here it is. I only have the cell phone to take pics with, and it's night time, so this is the best I could do.
Old 09-19-2011, 05:53 AM
Irelands child's Avatar
Are you completely sure that the leak is at the joint and not oil that's wicking along the bolt threads? That oil will ooze and any air flow will spread it all over quite easily. I had a problem with the actual differential retaining stud/nuts on the three bottom after I put mine in the housing.
If it is the retainer seal, while it can be replaced while lying under the car, I believe that I would prefer pulling the entire differential and doing the repair on the bench. It's cleaner and the chances of messing up the new O-ring is much less. Might even consider replacing the pinion seal too.
Dave W
Irelands child
Old 09-19-2011, 10:39 AM
adam83's Avatar
I hosed it all down with Brake cleaner, and let it sit, and I could see oil starting to build up a little in the 2 places I mentioned. Every time I go out to the garage, there is a small but growing puddle under the diff. Im to busy right now to dive into taking the whole thing out. I would like to, but I've never done it before, I dont have help if I need it right now, and if I need special tools I cant afford them at the moment. It's just not in the cards right now.
Old 09-19-2011, 11:08 AM
prostreet6t9's Avatar
Differential/Driveline
If it is just leaking from the Pinion support NO need to remove the whole third member.
Remove the pinion support. Keep the original shim as you will want to reinstall it to keep your pinion depth the same.
Replace the o-ring. I use a little silicone on the o-ring to help with the seal.
Easy fix.
Old 09-19-2011, 11:14 AM
Google Ratech# 5102 for the o-ring.
Old 09-19-2011, 11:40 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I know that they use copper washers on the 10 studs that hold the center section to the axle housing. IF the oil is wicking around the threads on those 5 bolts on your retainer, this might be a possible fix for that as well?
Hmmm ... just had another thought.
Check your diff vent to make sure that it is clean and free. If the diff is pressurizing, it will push oil out the smallest of areas.
Old 09-19-2011, 02:56 PM
adam83's Avatar
hey prostreet69, I saw your reply to this same question in another thread, but at what point in these instructions for replacing the O-ring do I replace the pinion seal on the flange?
Remove the 5 pinion support bolt's.
remove assemby.
Remove old o-ring
Clean the oil off pinion support and case
Install new o-ring with sealer
Install assembly
Clean any excess sealer
Old 09-19-2011, 03:28 PM
Unless you have access to a lift, that is a tough job while laying on your back with gear oil dripping off your elbows But of course, it can be done
Dave w
Irelands child
Old 09-19-2011, 04:27 PM
remove assemby.
Remove old o-ring
Install assembly
Replace your pinion seal after you get the pinion support out. Make sure you put the pinion preload where it was.When your installing your pinion nut,put a little sealer on the back side of the nut. That will stop any leakage from the center of the yoke.
Dont get the pinion preload too tight!
Old 09-19-2011, 10:49 PM
adam83's Avatar
oh crap... I dont know what pre load is...
8" Ford diff leaking around pinion nut Curmudgeon29 Transmission - Rearend 5 09-05-2011 08:15 AM
Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! artillerystevens Transmission - Rearend 6 04-10-2011 03:57 PM
Ford 9" pinion retainer bolt pattern crazyj Transmission - Rearend 0 10-11-2009 07:24 PM
Ford Nine Inch - Pinion Retainer Leak JC6715 Transmission - Rearend 14 04-09-2009 10:37 AM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
