Ford 9" partial disassembly? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 11:38 PM
After finally putting my new center section into the housing and filling the diff with gear oil I discovered an oil leak. Inspection revealed that the leak is not coming from the centersection/housing interface but from the nose of the center section. It's not from the pinion shaft oil seal but from the "cover plate" that bolt to the nose of the cernter section. So I need to pull that cover plate off to reseal that joint. Is it possible to pull the cover plate off without tearing the whole diff apart to reseal the nose?
Old 05-22-2012, 08:12 AM
S10xGN's Avatar
Gotta love a turbo!
Yes. It may have shims between it (being the pinion support) and the case and you must reinstall those shims or risk ruining the gear set. Also, go light on any sealant as that could affect the pinion depth to a minor degree...
Russ
Old 05-23-2012, 05:25 AM
OK, so can I get in by unbolting the pinion shaft input cover or do I have to pull the center section out of the diff housing and essentially rebuild the center section?
Old 05-23-2012, 06:56 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
No, you can remove the pinion support without taking anything else apart. That part should be sealed by a large o-ring, so you may want to make sure there are no sharp edges in the case itself that could cut the o-ring. I usually use some "Right Stuff" on either side of the o-ring, and in the "corner" where the pinion support meets the case, but try not to get any in the shim area, as S10xGN said, it can and will change the pinion depth a bit.
Old 05-23-2012, 04:07 PM
Thanks. I'll give that a try on Friday.
"Basics of Basics" Conv top pump/motor disassembly and rebuild. MARTINSR General Rodding Tech 36 07-23-2016 08:28 PM
"Partial Zero"?????? MARTINSR Off-Topic 6 06-05-2010 11:18 PM
1938 ford rearend disassembly kellison Suspension - Brakes - Steering 3 05-18-2010 06:59 AM
Need help with Ford 9" rear end disassembly retiredfireguy Transmission - Rearend 15 12-19-2009 08:24 AM
Ford 8 inch disassembly? pcoghlan Transmission - Rearend 22 03-02-2007 08:31 AM
