ford 9" pinion offset - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2004, 09:35 AM
Does anyone know exactly how much the pinion is offset to the right in a ford 9" chunk?
thanks
Old 10-28-2004, 07:35 PM
It will vary ...........from vehicle to vehicle.
A Ford Econline has more than say.......a 69 Mustang.
A 68 Bronco has more than a 68 F100.
http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm
Old 10-28-2004, 07:41 PM
pro70z28's Avatar
Last journal entry: "Z" construction
My 9'' is offset 1 1/2''.
Old 10-28-2004, 08:50 PM
Thanks pro, that's what I got roughly without using any fancy levels. As you got it. it was the offset of the chunk rather than the housings end I was interested in.
Old 10-28-2004, 08:58 PM
pro70z28's Avatar
Mine is apart so I measured the axles. 1 is 3" longer than the other.
Old 10-28-2004, 09:56 PM
Does that 3" longer axle put your pinion exactly in the middle? I plan on having my pinion 3\4" to the right and my calc was one axle just under 4" longer than the other but won't know for sure until I set it in place and take some measurements.
Old 10-29-2004, 07:35 AM
pro70z28's Avatar
My pinion is in the middle and the housing is centered from the back also. I have an aluminum modular housing so it's been built to center that way. You can see where the center section mounts offset in the housing. Unfortunately with a factory housing you have to center the pinion or the housing or split the difference.
Name:	3-1-04 chassis.sm.jpg
Old 10-29-2004, 10:27 AM
Thanks for the info. That all fits in with what I had roughly measured. This is the first 9" for me and they sit quite a bit different than 12 bolts so wanted to make sure I was on the right track in my thinking. That is a very serious looking car you are building. Looks great.
Old 10-29-2004, 06:46 PM
pro70z28's Avatar
Thanks
