Ford 9" pinion seal started to leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 11:34 AM
41 kustom's Avatar
I had a leaky rear end. Got that fixed so let's talk about my car. No really, my Ford 9" pinion seal started to leak so I replaced it and when I refilled it i got about a quart and a half of fluid back in. Do you think I need more or is this enough? Thanks.
Old 11-06-2012, 12:29 PM
big gear head's Avatar
High Performance Rear Ends
If oil is running out the fill plug on the front of the case then you got enough in it.
Ford pinion seal Jake Jacobs Transmission - Rearend 8 10-30-2010 02:25 PM
12 Bolt Pinion Seal night rider Transmission - Rearend 7 06-17-2009 12:16 PM
Ford Nine Inch - Pinion Retainer Leak JC6715 Transmission - Rearend 14 04-09-2009 10:37 AM
Pinion seal replacement malc Transmission - Rearend 5 11-08-2003 08:17 PM
Pinion seal sleeve? tommytempest Transmission - Rearend 3 05-08-2003 01:49 PM
