Ford 9" Question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2008, 10:17 PM
S10xGN's Avatar
Gotta love a turbo!
Ford 9" Question...
Hi All,
I recently bought a used NASCAR locker off E-Bay that was advertised to fit either "B" or "E" cases, "B" being a 2.89 bore case and "E" being a 3.06 bore case.
I have the large bore 3.06 case and cannot find a carrier bearing to fit...because...this locker has some off the wall diameter bearing surface that's not stock (stock being 1.78" diameter and this locker being 1.62 diameter). I have contacted the seller and he's "looking into it". There are bearings to fit a "B" case and I can trade out with a bud in order to get it put together...but...this problem got me to thinking.
Could a spacer be used? It wouldn't be a problem to make one, it'd only have a wall thickness of 0.080" though...
Russ
Old 03-02-2008, 07:03 AM
get ahold of an industrial supply warehouse such as motion industries that do industrial bearings.Tell em what ya got and they should be able to get bearings for ya.
Old 03-02-2008, 11:11 AM
S10xGN's Avatar
Gotta love a turbo!
Haven't called Motion (yet), but I did try and stumble through their online catalog. Wasn't much help there...
Russ
Old 03-02-2008, 01:59 PM
What you have is a pre-1970 locker. The change was made to 1.78" to accommodate 31 spline axles. I am not aware of a bearing with the 1.62/3.06 dimensions.
Old 03-02-2008, 06:43 PM
S10xGN's Avatar
Gotta love a turbo!
Since I'm already semi-screwed, I better go check and make sure it's a 31 spline (as advertised). Might have to go to plan "C"...
Russ
Old 03-03-2008, 11:17 AM
S10xGN's Avatar
Gotta love a turbo!
Phew! It's a 31 spline and a bud is gonna swap out my 3.06" case for a 2.89" case, so I'm good to go. The locker came with old bearings which are in good shape too...
Russ
Ford vs Chevy question savman1 Engine 31 10-14-2008 08:13 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 01:44 AM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
Ford 9" question bonuts Transmission - Rearend 1 08-25-2003 08:03 PM
