Ford 9" question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2003, 05:45 PM
bonuts's Avatar
Got Ouzo for touzo
Thumbs down Ford 9" question
So this weekend after winning the main event in my circle track car, I was being dumb and did a burn-out----Well the 9"grenaded and I feel like an *****.
Anyways the rear end I run is out of a early Ford Bronco, and the pumpkin is off-set, one axle is 27"s lond and the other is 29". Both are 31 spline axles. The 27" axle snapped and wouldn't you know it they are near impossible to find a replacement. I have however found a axle the right length but 28 spline.
So heres my question can we make the 28 spline axle, and side gear work in a 31 spline housing. Are the housings all the same (28 & 31 spline)? I'm no expert in rear ends so any help would be much appreciated. I need this thing bullet proof for the last two races of the year, being first in points as of Saturday and have two other drivers in striking distance if I have rear-end problems.
Also I have heard that if the rear-end broke doing a burn out it was probably going to fail down the road anyways, what do ya think? I would fell like less of an ***** if this could be true.
bonuts
Old 08-25-2003, 07:03 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
http://hiqties.hypermart.net/9inch.html#housing check this site out, its all about ford 9inch rearends..........joe
