Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
Old 04-08-2013, 08:59 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
The springs are all the same. Some people leave 2 springs out if they want it to be a little softer for street use. I don't know of any manual. I shim the clutches in the 9 inch a little looser than I do in a Eaton Posi. If you shim them tight in the 9 inch they will pop and make a lot of noise.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-08-2013)
