Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
Old 04-15-2013, 10:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I think you're right to be concerned, but BGH will clear this up for you I'm sure. In the meantime all I can offer is on the ones I've seen the bearing ID had an adequate radius to accommodate the fillet on the carrier. If I was up against this and had no one to ask I'd relieve the inner bearing race ID enough to clear unless a different bearing would clear.
I have had pinion shims w/ID too small to sit flush w/o being opened up to clear the fillet... but that's a different deal obviously.
Good luck.
