Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
Old 04-15-2013, 11:04 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The bearing must sit complete against the flat surface on the case. If it doesn't then you will have probblems later. Use a .001 feeler gauge to see if it is seated all the way.
