Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
  #19 (permalink)
Old 04-17-2013, 07:10 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
I don't set the clutches like that. I put a shim in and assemble the differential without the springs, then stick it on an axle stub in a vice and turn it. If the resistance is too high I use a thinner shim. If it isn't enough then I use a thicker shim. When the resistance is where I want it then I put the springs in and call it good enough. You can't assemble one of these as tight as you do a Eaton Posi. If you get it too tight then it will pop and growl when turning a corner.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-17-2013)
