Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
  #34 (permalink)
Old 05-17-2013, 07:36 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
If that's an accurate pattern then it looks great. That's almost complete tooth contact. I don't think I have ever seen one with that much contact area before. May just be the grease that you used.
The clutches should be tight enough that you can torque the ring gear bolts and not ever feel anything slip. I've had to take these apart and remove shims because they locked up too much.
