Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
  #36 (permalink)
Old 05-17-2013, 10:58 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
You can get the gear marking compound at many GM dealers. It's hard to use a press and get the gear on straight. You have a pretty good way of doing it. I don't know why your clutches are not holding. The springs should be enough to keep you from being able to turn it. I don't set the shims the way you are doing it.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-18-2013)
