Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 9" Questions...
  #43 (permalink)
Old 05-20-2013, 10:48 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
Are you using a axle shaft in both sides when you are checking this? If you don't have a shaft in the side with the split gear and clutch hub then the break away torque is going to be much less because these two parts must have a shaft to lock them together.
