Ford 9" Questions... - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 05-23-2013, 12:30 PM
big gear head's Avatar
High Performance Rear Ends
I'm sure that there is a tool for that, but I don't have one. If I can turn it by hand then it's loose. Most of the time they don't turn when I torque the lug nuts.
Good luck with the shoulder. I just took the ice pack off of mine.
  #47 (permalink)
Old 05-25-2013, 09:32 PM
S10xGN's Avatar
Gotta love a turbo!
BGH,
I was bad! I went out and finished torquing the ring gear bolts and setting the backlash (all with my left arm). Using my homemade yellow "paste" I changed pinion shims from 0.027" to 0.038" to 0.050" and could not discern any change in pattern, at all. After wiping it all down, sticking in a single 0.020" shim, setting b/l at 0.008", and using some Prussian blue compound, this is what I'm now looking at. By then, my arm was getting sore so I quit. The coast side is fairly pronounced, but the drive side doesn't show as well. What's the verdict?
Russ
ID:	74296   Click image for larger version
  #48 (permalink)
Old 05-25-2013, 10:14 PM
I've never been able to read a pattern with that blue stuff. I can't say for sure.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-26-2013)
9" ford nodular questions hammerhead Transmission - Rearend 0 05-06-2006 01:34 PM
Ford 9" Questions ATX30Sedan Suspension - Brakes - Steering 4 03-03-2006 11:29 AM
Ford 9" questions 85Sierra Transmission - Rearend 2 02-22-2006 10:37 PM
Ford 9" questions jimmy p Transmission - Rearend 2 09-25-2004 09:31 AM
Ford 8" / 9" Questions DusterNut Transmission - Rearend 1 01-02-2003 12:49 AM
