Ford 9" questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2004, 10:45 AM
New Member
Ford 9" questions
Im considering replacing my 10 bolt on my custom hot rod truck with a ford 9". Ill be running a 400rwhp ls1 and the 10 bolt is a stock non-posi unit. Probably a good idea to replace it right?
Ive got a couple 9" rears laying around that should work or i can find more. Ill need a posi unit, probably different gearing and a disk brake kit. Can someone point me in the right direction for these parts? Maybe a general price range i should expect to pay?
What about changing the lug pattern to 5 lug chevy?
Id imagine my stock driveshaft wont work with the ford 9" either..where can i get a new one?
thanks alot
oh here is a picture of it...
no its not a "low-rider" ...i think of it as a street rod stuck in a trucks body
Old 09-24-2004, 11:26 PM
New Member
anyone? Mostly i just want to know how to convert it to 5 x5 chevy pattern.
Old 09-25-2004, 08:31 AM
Crosley's Avatar
Wiki Edits: 1659
Cool
To change a wheel bolt pattern you either ;
get new axles & rotors,
re-drill the axles and disc rotors
use wheel adapters to change the bolt pattern.
In my opinion adapters are unsafe
