Ford 9" Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2006, 10:33 PM
ATX30Sedan's Avatar
Ford 9" Questions
I've got a complete Ford 9" rear end that I planned on using on my 1930 Model A Sedan. Now I'm concerned that the rear end will be too wide and the wheels will be sticking out.
SoCal's website states that a flange to flange width of 52" is ideal for a Model A. I've got a 60.5" housing (housing flange to flange)! Am I paranoid or will this look like hell? It's not mounted to the vehicle yet, so I have no frame of reference other than laying it under the frame and body.
Thoughts?
Nick
Old 03-01-2006, 10:47 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Ford 9" Questions
That works out to 4 inches wider on each side. Some of that could be compensated by wheel offset. Looks like it will be fendered? Wider rear fenders will camouflage that as well.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-02-2006, 09:11 AM
ATX30Sedan's Avatar
Open wheel. I will have to check the offset on the wheels I plan on using. Hopefully they will make up for some of the gap.
Old 03-02-2006, 10:33 AM
New Member
9" Ford rear end to wide
I had the same problem [9" in a '36 Hupmobile]. Here in California there are several businesses that narrow rear end housings. Curries comes to mind. Cost me around $350 to narrow the housing,buy one new axle, and respline one old axle. Ed Farrell
Old 03-03-2006, 10:29 AM
astroracer's Avatar
How much power is the motor gonna put out? If it's a driver an S10 rear will fit perfectly. Trade the 9 inch (or sell it) and get yourself a housing out of a late model Blazer if you want discs.
Mark
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
Ford 9" Rear End Narrowing nightrain_rod Transmission - Rearend 3 11-30-2003 11:50 AM
Ford 9" MARKDEB Transmission - Rearend 2 01-31-2003 07:28 PM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
